Im using a box blade with about 300# of weights as a ballast for my FEL. Are you guys using anything (chains) to support the weight and take the load off of the hydraulics.....or not???
Hmm... I'm not using 3PH ballast yet, though it's on my "project list"; you raise a question that hadn't occurred to me. My 3PH leaks down in about 5 days with only a Triton 3PH hitch on it; however, I doubt I'd have that problem while running the loader.Im using a box blade with about 300# of weights as a ballast for my FEL. Are you guys using anything (chains) to support the weight and take the load off of the hydraulics.....or not???
mikkeeh,Im using a box blade with about 300# of weights as a ballast for my FEL. Are you guys using anything (chains) to support the weight and take the load off of the hydraulics.....or not???
