I'll be looking for a nylock of a suitable size...thanks Daren, I didn't know much about them. This had a lock washer, but obviously not working as intended.
"Lock" washers don't, really. (May be a thread on OTT about that, but the bottom line is a flat washer is more effective, and if used, a lock washer should be used between a flat washer and nut.
When looking for a Nylock-style nut, be sure to get one that will leave one and one-half threads exposed. If the threads don't extend out of the Nylock nut that far, the nylon insert will not be gripping with its designed potential.
I much prefer Loctite, in any color. (Even blue will be better than a "lock" washer!
I ground a flat spot in the bottom section of the ball, and welded a piece of 5/16 square key stock to the receiver hitch. It locks the ball against a flat surface, so you can tighten the nut, without having to remove the trailer. Now wal-mart sells a similar setup with hex, formed in the bottom of the ball, and has a matching receiver hitch, that has a punched hex in it to achieve the same idea... I coulda made some bucks...
Yep, Reese offers the "regular" one, or one with a hex indentation, and balls with a hex profile that matches. A bit more $$ but they've got you by the...
Install ball,torque to specification and tack weld nut. Achieving that with a 1"shank ball would be difficut to achieve as its over 600 foot-pounds torque.
3/4" bolt style is over 250 foot lbs. difficut with regular type guy tools.
the flat bar welded to bar is a great idea. Ball cant turn.
Welding would certainly be a permanent solution. I'm not convinced that I'll always need to use a 2" ball, so I will just settle for Loctite for now. Intellectually I know that a jamb nut would be more secure than Loctite, but I guess I'm kinda stuck in my ways.
I hadn't considered the torquing requirements... how long a cheater bar would I have to use... Oh, skip it, I'm not going to go shopping for 1" drive wrench and sockets!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'll have to take my chances with 3/4" air impact wrench.
