Bush Hog HP Requirements
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
323
Mobile, AL
I have an L3800 HST and the HP at the PTO is approximately 30. I found a used bush hog and the manufacturer's website states that it's not recommended for tractors exceeding 30 HP but it has a 40 HP gear box. Do you think the mfg is referring to the HP at the PTO or the engine? They are closed on the weekends otherwise I'd call them. It's a good deal but I don't want to tear it up. Here's the link to the model - Andy 500. Thanks
http://www.lowerymanufacturing.com/Clippers.htm
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
I have a 45 hp tractor with 37 hp at the pto and use a 5ft. land pride brush mower with a 40 hp gearbox. I have no problems with it but then again, I'm not trying to cut 2" trees with the mower. It works fine for me.
Sammy3700
Feb 20, 2012
461
61
Red Springs, NC
You will be good with that set up. Both of ours are 40 hp gear boxes and I have a L3700SU and my dad's is a L3800.
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
I think the old "rule of thumb" is 5HP for every foot (width) of implement.
I've seen the 5 hp per foot of mower posted many times. Applying this to a 6 ft bushhog would equal 30 hp. I can't imagine using a 30 hp tractor to power a 6 ft. I guess if you go very slow and cut light grass it would cut ok, but lifting a 1,000 lb mower (or even an 800 lb one would likely make that tractor unstable. I have an 800 lb disc harrow behind my L3010 that requires the FEL be on to keep the front wheels on the ground.
7,527
Tennessee Kubota Man, are you saying a 6' brush mower weighs 1000#?
I've got a 10' Bush Hog (brand) with 3 gearboxes and a lot of iron and I doubt it weighs 1000#. I've used it for years on a 55 HP 730 Case tractor.
D2Cat, my Landpride 6' is around 800 lbs or so-2" cutting capacity. The next step up in Landpride 6' is 1,046 lbs with 3" capacity. These are single spindle mowers. I'm sure there is a wide range depending on how heavy duty they are. I pull mine with the M5140 (51 hp). What model Bush Hog do you have?
I cut grass commercially so want to mow fairly quick. A lot of the mowing is cutting heavy bahia grass so I base my comments from that angle. I know a guy who has a green 40 hp and runs a 7', but he tells me he doesn't get in a hurry.
7,527
TKM, I don't remember the model of the mower. I sold it 2 years ago and it was probably 20 years old. It was a pull type, not 3 pt. It had two solid tires on each corner with hyd. cyl to raise and lower. Maybe the thing did weigh a kazillion pounds, I just never thought it would be that heavy.
I mowed in a fairly slow gear, usually in weeds, brush, or crop stubble.
The reason I got rid of it is because my neighbor used it more then me. His philosophy was, "You buy it, I'll borrow it."
Ha, ha.....yeah I know about those folks who want to borrow. :D
Just out of curiosity I looked at some of the BH models 3 spindle which were around 10' of the pull type and they were around 2,000 lbs. More than I'd thought. I'll bet your older one was built like a tank!
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
I prefer the 5hp per foot rule, along with some common sense. I have 19-20 pto hp, so Ill stick with my 4', which weighs around 500-600 lbs. Pto hp is almost as important as your machines ability to safely utilize said implement. Im not comfortable trying to stick a 5' grinder on my machine, she's just not heavy enough, or wide enough for my terrain.
Id rather have more control/stability and go a little slower than try and bang out the job over-working my tractor.
MadMax, the 5 ft rule is probably a good starting point and as you say some common sense should be used. Using pto hp rather than gross hp makes more sense to me. Each person's requirements/situations are different. Wish I didn't have to deal with bahia grass sometimes....
bambam31
Apr 3, 2014
323
Mobile, AL
Thanks for everyone's input. I purchased the bush hog today for $450. It's a 2009 model he purchased brand new. He used it a few times and it's been residing under a tarp for about 4 years. The blades are still sharp and have no nicks. I'm planning on changing the oil in the gear box. Never done that before but I'll figure it out.
