What kind of chainsaw you have?
7,124
Where I come from, it's not do you have a chainsaw, it's what kind of chainsaw to you run??
I find many are loyal to a brand. Mine is Stihl, but have had other makes over the years.
This is my current arsenal. Stihl 046 Magnum and MS211. The 046 is a "big boy" saw, but that little 211 is a joy for cuttin' brush.
What you got?
PHPaul
Apr 2, 2015
1,216
1,442
Downeast Maine
www.eastovershoe.com
Another Stihl man here. Just little guys for working up firewood and trimming, but both are beasts. OLD beasts...an 025 and an 011
2,916
What you got?
Stihl 028 super wood boss, bought in 87...still running....like a champ.
038 ....stole IT off craigslist.... 150, runs like a champ too:D
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
I have a couple of toys; a 20" Ryobi and a 14" 40V battery powered Ryobi. It does ok on pine but I need a good Stihl for some bigger stuff I have.
hodge
Nov 19, 2010
2,959
535
Love, VA
Stihl chainsaw, Stihl weedeater, Stihl backpack blower... see a theme?
7,124
I started with a tiny Skil, maybe 10 or 12" bar. I was probably the same in age. We were farmers - - you started young...
About 1980 the new Stihl 056 Super came along!! Hold the phone - - -Now that's a saw!! :D:D
Still runs strong today - but she's a heavy brute. I used to cut spruce pulp with it - couldn't today. Bitch to get old.:rolleyes:
Made me a Stihl guy to this day....guess what my trimmer/brushcutters are??
Just watch the ethanol gas - bad news for these machines.... :mad:
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
All stihl, here. Favorite little saw is the MS 200T limbing saw. Hate how the alcohol in todays fuel affects all 2 strokes, now. I run mine on Naptha, or Coleman camping fuel it's cheaper, in the long run to run high $ fuel through them, than to put new carbs and hoses on them...:D
7,124
Hodge - I do, and I'm with you. My buddy is the same, too, but everything is Husqvarna.
It seems like there is so much brand loyalty with this type of equipment. One guy is all Stihl, the next is all Husky, and never shall they mix. :cool:
4,600
I have an OLD Mac 10-10 pro out in the barn a beast and heavy as the dickens,, Bought a new Husky 350 it screams, and cuts like crazy,, damn thing self destructed second year,, I keep putting it back together,, maybe its time for a new one
mdhughes
L3901DT
Dec 10, 2014
1,400
1,282
Ste Geneveive county, MO
Husqvarna 372XP 24" since 09 Aug 2014 and a Husqvarna 359 20" since 29 Dec 2004. Run skip tooth chains on both. I have fell a lot of trees with the 359, most over 60" at chest height. We heat our house with a wood burning boiler.
OldeEnglish
Jul 13, 2014
766
Western, MA
I have all ECHO power equipment, just a small chain saw for firewood. It's not that I don't like husky or stihl, just don't like the local dealer :rolleyes:. My local echo dealer is great to deal with and I've had great luck with it. I love the power head that can switch between pole saw, wacker, and broom.
8,893
I have two husqvarna 445's with 18" bars. First one I had for three years. Loaned it out :rolleyes: got it back with no compression, bent chain adjuster, bent bar, and a chain that looked like they tried cutting a bundle of rebar with it :mad: they ran it for a week on straight gas. Not sure about the rest. ended up replacing it and keeping the junk one for parts if needed. Have had this one for two years now. Had a small stihl years ago that probably was a lemon. Won't buy another one personally.
bmblank
Mar 4, 2015
744
446
Cadillac, MI
I just recently got a hand me down husky 365 from my fil. runs like a champ. I just need to lift some weights and get strong enough to use it. Fil is a logger... it was one of his little saws.
Sent from my XT1254 using Forum Fiend v1.3.2.
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
11
Lovells, Mi
I have a couple of small Husqvarnas for cutting down dead trees and clearing the road. Earlier diydave said he had trouble with alcohol in the gas. There are a lot of boat and ATVs and snowmobiles in our area and one of the gas stations agreed to carry non-alcohol gas. Some marinas also carry non-alcohol gas as a lot of outboard boat motors have problems with the alcohol. I am in the process of eliminating all the alcohol from my small engines.
olthumpa
L275
May 25, 2011
1,501
Maine
Husky 440
Husky 455
Husky 72? cut off saw - not here
Husky 77
Stihl KM 130
Stihl FS 130
Stihl BR 350
Tooljunkie
May 13, 2014
4,150
34
Husky is my preference. Fixed a lot of stihls, but never any major problems.
Ethanol in fuel is killer on small engines.
Our ethanol enhanced fuel is not more than 10%. I call BS. I scanned an impala a while back, ethanol level according to the sensor was 19%!!
Customer switched service stations and went to premium gas and issue went away.
More ethanol requires bigger jets.
Changnam 59
New to the world of Orange
Dec 24, 2011
73
Pathumthanee, Thailand
I use a Stihl MS180 with a twelve inch bar.
It was the largest I could buy as larger chainsaws require a government permit which is not easy to obtain. The reason for the permit system is because of the use of large chainsaws in illegal logging.
Initially I ran it on Castrol 2T but since changing to the super expensive Stihl 2T it has been much easier to start. This may be because the Stihl 2T has a very neat measuring and dispensing system and so, most likely, my oil to fuel ratio is more accurate.
I avoid gasohol like the plague. It has cost me a lot of time and money in repairs to classic cars and motorcycles and I am not going to put it in a 2 stroke motor that runs to 10,000 rpm and is subject to infrequent use.
I have engaged in plenty of risky activities in my time but for some reason it is the chainsaw that gives me the jitters.
It would cost a lot less to run if I could master sharpening chains. I have the right tools but just cannot get it right.
