Radiator help
smokey196240
Gray
Feb 14, 2012
Reserve,Louisiana
Radiator help L 185
Looking for a radiator for a L185 Serial No L 185 - 56179 , Engine No. Z 751-A cant find one at dealer they said discontinued, so here i am asking for help thanks .
9,118
If you have the old one. Do a google search for your area for radiator repair. Should pop up the local guy. And see about getting the radiator recored. Or better yet, I found one for an l175, with the z750a motor. Link shows the measurements so you can compare to yours.
http://www.grainfarmer.com/kubota-radiators/Kubota-L175-Radiator.html
smokey196240
Gray
Feb 14, 2012
Reserve,Louisiana
Thanks for the help the one we got is so bad that its beyond repair local dealer says L 185 has been discontinued and today was told the L 175 radiator is the same size but the mounting bolts at bottom would have to be cut off and rewelded to fit the L 185 anyone know anything about this and how hard this is to do
7,702
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
smokey, maybe you didn't like the previous link? Here's another.
http://www.ebay.com/itm/New-Kubota-...169?pt=LH_DefaultDomain_0&hash=item5882cabe81
New radiators are not inexpensive. Get the correct radiator. It may save your engine from overheating.
According to the listing the mounting is the same, or they couldn't be listed the way they are. They'd be getting too many returns and complaints.
Its likely what I call a will fit. All the bolt holes are already in position so the radiator will fit the models listed. Just keep the old radiator, so you can see the minute difference, in the bottom end...:D
smokey196240
Gray
Feb 14, 2012
Reserve,Louisiana
I did like the link just making sure before throwing down 350.00 bucks thats why i ask because im a plummer not a tractor guru like you guys just learning :D and i do thank you guys for any and all help im just a little slow :eek:
