L175 rear rim\center
Carson946
L175.
Mar 14, 2015
Mountain View Arkansas
Hey I just bought a L175 Last week .Some po at one time or other put the wrong rear Rim\Hub on. I'm needing to know what other rim hub will fix it this tractor. I've called west ky tractor with no luck. I like to find the rim hub that holds the tire 8.3-24. THANKS
Tooljunkie
May 13, 2014
4,150
I dont have a l175, but im sure neither wheel applies to this tractor,causing binding and damage in the 4wd. If you can source a manual, im sure the tire sizes are in specification chart. I just saw a set of four for a DT tractor for $400, so im sure you can find proper used wheels somewheres.
Tooljunkie
May 13, 2014
4,150
You could try tucker tire for a tire / rim set for you.
http://www.tuckertire.com/
Being that you have a 2wd just about any size tire/rim will work for you.;)
I can imagine what you are thinking, i saw what looked like a 4wd axle tube and ,well you know the rest. These darn pictures are like dots on my iphone and i dont look so good up close. Wheres my darn glasses?
You dont want wheels i want. Too bad mine are 8.30/22. There is a guy selling new 24's for 100 apiece.
