So what do you use, gravel? Does the farmer dress the driveway (at least as far as the gate)?... farmer uses my driveway for field access. im afraid it would get torn up in short order...
Its a 700 foot gravel driveway,with a slight slope to the road, seems to be the path for water to run off.the landscape changes year to year from the frost going down as far as 4 feet in places, reccomended depth for water lines is 6 feet. The nearest source for millings is 60 miles away, depending what its worth i may consider it. Just for parking aeas.So what do you use, gravel? Does the farmer dress the driveway (at least as far as the gate)?
On second thought, I suspect that your frost heave would do more damage than the farmer. But my little piece of inheritance in s.w. Louisiana might really benefit from millings.
If I understand correctly, the runoff goes down your gravel driveway. Prolly washes some gravel; paving would prevent that, but I think it would promote an erosion problem on the lower edge of the pavement.Its a 700 foot gravel driveway,with a slight slope to the road, seems to be the path for water to run off.the landscape changes year to year from the frost going down as far as 4 feet in places, reccomended depth for water lines is 6 feet...
Don't use diesel as it will strip the asphalt off the rock!My 800'+ driveway is in millings. Above advice is good. Mine wasn't rolled down with a roller, just by driving on it. Recommend the 6" layer to start also. I too read about using diesel on a hot day but haven't found it necessary.
