b6000 front axle leak 4x4
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
This morning there was a puddle of gear oil under my left tire. didn't have time to take anything apart, but from what I can tell it is leaking between the rim and the hub. No longer leaking so I don't know where to start if I do take it apart. What should I look for? I see an oil seal in the parts manual could that be the only thing wrong or do I have to dig deeper?
7,259
You could get lucky and have just a failed seal, but normally the seal failed because of a bad bearing. ;)
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
I can order the outer bearing and the seal. Is it something I can do in the garage or do I need to have it pressed out and pressed back.
what are your thoughts, do I have to do both inner and outer bearing or the outer only?
7,259
Yes you can do it all, nothing is pressed in, Snap rings hold parts in place, well the seal is pressed in but that's easy to get out.
Pull it apart first, you might get lucky and it was just some trash that ruined the seal.
If the bearings are bad yes there is an inner 48 and outer 49 and 51 is seal.
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
just received all of the parts from Coleman's Equip.
will start work this weekend but before starting Is there a way of knowing if it is just the oil seal that is leaking? will there be any signs of bad bearings? if it spins fine without noises or if it does not have any play in it would it be safe to say it is the oil seal only?
let me know what you guys think
Thanks
TKBOTA
B6000 4x4 FEL
Feb 6, 2015
30
Long Island, NY
I am not getting far. I removed the bolts from the gear case cover and I can't get it to separate. Am I suppose to take something else apart in order to open it up
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
My B6100D manual says "remove the 14 bolts... push and release the dust cover..."
Our machines must be different; I don't have the parts diagram the NIW posted. However, there shouldn't be anything except those bolts to deal with until you get it opened. I expect you need to employ your "persuader" (rawhide, lead, or brass).
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
Are you using the service manual? Page 22 gives step-by-step guidance.
7,259
It should just split and come off, might be bonded by the gasket.
