local dealer has a 1998 b20 coming in with FEL, backhoe and canopy. Wants 13,000-13,500 for it depending on what they have to do. estimate trade in value for b9200 at 3-4k. lower hp with same lift capacity. Dealer claims even with lower hp than the b9200 that the b20 is a more powerful machine because of the hydraulics. Would i basically be paying 10k for a backhoe? wheel base actually slightly narrower on the b20. would i be better off finding a way to spring for the bx25d?
Currently have a non hst b9200
1. Need a backhoe
2. Tippy, would like to have more stability as we have a hilly terrain
3. Would like power steering and hst
4. ROPS that is tall enough so if i did roll over, my head would not hit the ground to protect the ROPS.
Looking at the 3 .....
WHAT HOURS ARE ON THE B20??????
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
MIGHT be the most important question here, can you see this machine and take a picture of it?
http://www.tractordata.com/backhoe-loader/000/1/3/130-kubota-b20.html
the B20 is a hellva machine, it has a pump that pushes TWICE as much fluid as the 25D.
The bucket on the B20 is WIDER......8" wider......
here is MORE info found on the B20 :
D950-A-T 56.6 cu.in water-cooled 3-cylinder diesel
20HP gross
17.5HP net
13.5 PTO HP @ 2600RPM
5.3 gal fuel tank
4.2 qts cooling system
4.1 qts engine oil
30.6 qts hydrostatic fluid
0-11.31mph traveling speed
Standard:
3-range hydro
540 rear PTO
Position control (3PH lift of 1279lbs @ LP; 1014lbs 24" behind)
Fixed mount loader
NO mid PTO
R4 tires (R1 rears optional)
Dual hydraulic pumps (one for FEL, one for BH ---12.7GPM total)
4WD
Power steering
Steel plate slanted nose
Dimensions:
106.7" length
53.7" width
60.4" wheelbase
9.2' turning circle (w/o brake)
TL420 Loader Standard (B20 TL)
56" buckets (square or round back... round is heavy duty) w/6.35 cu. ft. capacity
86.3" max lift height
66.1" clearance w/bucket dumped
23.8" reach @ max height
40 degree max dump angle
56.9" reach on ground
40 degree max rollback angle
6.5" digging depth
926lbs max lift capacity
1543lbs breakout force
Lift to full height in 2.9 seconds
Rollback in 2.3 seconds
Standard self leveling
BT750 Backhoe Optional (B20 TLB/BT650 standard)
92.9" digging depth
(750 stands for 7.5' digging depth... 650 stands for 6.5'. Later models all came with the 750.)
Now as for the BX25D.................now you talk about the little train that could .....this is a machine that will move a mountain, ONE bite at a time, I have had one for 2 years, fineeeeeeeee machine. Really- Really worth every penny that you spend on it.
Your B9200 has a four banger, where the other 2 only have 3 cylinders.
Your machine now will burn more fuel per hour I am going to guess than the other two.
the B20 has a width of 1.5" less than yours .....
the BX25 will be a lot narrower......44.5 wide
Based on what I read - your 9200 has a FEL - and it is a 50" bucket?
The real meat comes down to this ............
B25D will be a NEW machine - your baby, if you buy you should be out the door in under 18,19K.....that is w/o mmm .....I paid right at 20k for all 3 parts.
The B25D is ALL hydrostatic .........steering is with your pinky! Rops and all that good stuff!
The B20 will come with much the same tires as you have now.....much bigger than the BX25.
and as far as trading in your machine, I would tell your dealer to go #$%#$@#.....well you know what I am saying......
look at some of these :
http://washingtondc.craigslist.org/nva/grq/4912470547.html
your machine is worth TWICE what your trade in - which ever you buy - keep this one - place it online and wait - someone will give you 6k for it (assuming it is in good shape)
If you do not have the cash up front to drop on the B20, then finance the B25 and pay 350 a month....then when you sell your B9200 - you will have cash in hand!
I would REALLY need to see the B20.....I think you buy it :
IF it has some hours lower than 1000 or close to it
If it is in "good" shape
AND I would test every aspect of it - especially the HOE
AND if the dealer gets under 12k!
