my used Kubota M5700 4 wheel drive tractor came with the following R4 Titan Industrial tires Front - 12.5/80 - 18<br/>Rear - 16.9 X 24<br/>...are these tires compatible on this tractor ?
Just a quick numbers check but they seem to be close enough to work and not cause any issues.my used Kubota M5700 4 wheel drive tractor came with the following R4 Titan Industrial tires Front - 12.5/80 - 18<br/>Rear - 16.9 X 24<br/>...are these tires compatible on this tractor ?
Tractordata.com only lists R1 tire sizes, they don't list the R4's.Tractor was still in 4 wd when I went on the road and there was a vibration and noise like the tires were out of sync. Also do not match Tractor Data .com
Yes tires are rim sizes can get real confusing, What maters is the RC Ratio of the tires, that ratio is the difference in damage or no damage.Found Listing for R 4s for an M4700 basically same tractor and they are correct ! I will make sure to take it out of 4 wheel drive the next time I take it on the road !
