We have 2 large gravel drives that I have to clear snow on so I decided to make some clamp on bucket skids to help keep from digging into the gravel.
I've been keeping the bucket tilted back just a touch and then putting it in float to leave behind the gravel and get most of the snow. If I tilt forward a tad to much I start scrapping the gravel up, If I tilt back too much I'm just packing the snow down. Plus there are several uneven spots so I end up catching here and there. I've thought about using the pipe trick but thought I'd give the skids a shot and I thought I'd share some pictures.
I started with some 1.5" x 1/4" steel and cut 3 pieces 8" long, these will be the clamp part of the skids.
Then I got the torch out and bent them so that they will loosely fit over the leading edge of the bucket. I made the bottom leg about 1/2' longer than the wear strip on the leading edge of the bucket.
Then I cut some 2" x 3/8" steel to 8" long for the skids.
And then welded the 1.5" pieces to the 2" pieces.
Then back to the torch to bend the leading and trailing edges of the skids.
Then I cut some 1" x 1/4" steel with the angle of the leading edge of the skid on them. These will stiffen the clamp part of the skids so they don't bend when you tighten the clamp bolts.
And then a little more welding.
Then I drilled and tapped the holes for the clamp bolts and ground the leading and trailing edges.
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-1.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-2.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-3.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-4.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-5.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-6.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-7.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-8.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-9.jpg)
![](http://www.zbcreations.com/b2620/kubota-b2620-bucket-skids-10.jpg)
