pulling stumps
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
The only snag I've run into is when I hit an irrigation line that was over a root end. Had to replace 12 feet of line but not a big deal. Thanks for the guidance. I can use all I can get.
Paul
IRRIGATION???? in Canada?
What do yall pump warm water threw it to melt the snow LOL!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
HAHA yeah I've seen that pic also. Makes ya wonder why everything is covered in ice but the top of the damn trees!
Foisy
Kubota L3240, Great Bend Backhoe, LA514 Loader, rear snowblower
Mar 28, 2010
52
Northern Ontario
Actually us Canadians irrigate cause we like to play in the mud. Sorry if this is a dirty picture!:D:D:D:D
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
I dug out some stumps the other day, I used the post hole digger and drilled all around the stump, then dug it out, made it allot easier.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
What did you use a 3pt mount post hole digger for the back of the tractor? If you did man you got lucky as hell. I was drilling a hole in my back yard one time to set a 6x6 timber in the ground for a fence post and I got the auger bit hung up on something. It stalled and shut the tractor off and I could not for the life of me lift the bit back out the ground. Took me 45 mins by hand with a pipe wrench on the PTO shaft to back the bit out the whole.
To this day I cant figure out what the hell I was hung up on, cause I was no where near any trees.
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
Eric, sounds like it tome for the cadaver sniffing dogs to pay a visit to your back yard :rolleyes:
Sam427
Nov 6, 2009
194
Snellville, Ga. USA
Yep, post hole digger on a 3 point. I just looked at where the big roots were and drilled around them, no problems.
Sounds like you may have wedged yours in some rocks. I have hit rock before and it sucks the auger down into the ground really quick. You have to ease it down in the ground and clear it often.
