My new to me L2050DT front tires are visibly worn and I'd like to replace them. The current tires have the following information on the sidewall: SuperStrong, All Traction Field and Road, 6-14 (not 6.00-14), 6-ply rating, G1, Made in China.
Nowhere is a tire mfg visible.
I have the Operator's Manual and it isn't much help either. The Specification Table on pg 8 says rear tires are 9.5-24 and the front tires are 6.00-14. Elsewhere on pg 25 there is an Inflation Pressure table that lists more than one tire size for both front and rear. However it is so kind as to show 6-14, 4PR tires. (6.00-14 not listed at all). It also shows 11.2-24, 4pr tires for the rear.
That's nice since those are what my rear tires are.
All are Ag tires R1
Thoughts: My tractor also has a BF400S front loader on it. I could see where 6ply rated tires would be desirable as the load rating of the 4ply tires is substantially lower.
I have searched old threads both here and on TBN and find similar discussions going way back. In shopping around for replacements I have found suitable 6-14 4PR tires and 6.00-14 6PR tires.
Though I won't be engaging 4wd all the time I do intend to use if frequently enough that I don't wish to be concerned about the front & rear being out of synch because I acquired the wrong size nor do I wish to pickup a good load in the front bucket only to collapse the tires because they can't take it.
Currently I'm leaning towards a pair of BKT TR126 6-14 tires because of their size and aggressive tread. They are tubed tires and are only 4PR rated.
Have any of you seen this comment by Miller tire before?:
"*NOTE** This tire size is 6-14 - Not to be confused with 6.00-14, which is a whole different tire. Please double check your size and feel free to contact us with questions before ordering.
MAX LOAD 660 lbs @26psi
33/32 Tread Depth
25 25/32" mounted diameter"
I've ordered from them before and liked the tires I received and their prompt delivery. However this comment has fixed itself in my noggin.
I even contacted a couple of tire places and they use 6-14 and 6.00-14 interchangeably. In searching online I know they are different but wonder if it is enough to matter.
Clear as mud.
All are Ag tires R1
33/32 Tread Depth
Clear as mud.
