Silencer forward or upward?
Best silencer direction?
  • Muffler forward
    Votes: 14 51.9%
  • Muffler upwards
    Votes: 13 48.1%
  • Total voters
    27
volp
Kubota B6001, MF35 with backhoe, Ford 3000, JD LX186 Lawn tractor
Dont know if this is the right subforum for my question?
I just bought a B6001 4WD which had the silencer mounted forward which I suppose is the most common way. My experience is that the exchaust gases sometimes tend to get in my face. My MF35 back in Sweden have an upright silencer as most bigger tractors.
What are you opinions on this? Forward or upward? :confused:
Anders
10,986
Upwards, heat rises! :D
Also if your using a front mount blade, Snowblower, or even a FEL, Up keeps the exhaust from bouncing off the implement and back at ya. ;)
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I have two tractors with muffler facing forward. No trouble at all. It also is less likely to catch on branches, etc. No rain gets in it.
3,056
I agree - after thinking about it a minute - I like forward, up is in the visual way and also something else to snag a branch.....also - you dont have to cap it it rain or snow in the vertical mount.:)
Orange Turbo
MX5100, pto13000kw, Loader, Ripper,Plow,Disc,Mower,Forks,3pt spreader,Box Blade.
Feb 2, 2015
175
Mo
If mine was upward, It would of been torn off more than once.
I also think, forward is a little more quiet. Less to look around, And less exh smell.
upward Is a little cleaner on the tractor.
It depends on your personal use..
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
Up looks cooler!
blank102
L3200
Feb 2, 2015
44
Mexifornia
I voted for upright. I've noticed that on my forward exhaust it gets in my lungs too often.
3,534
Up- mine was forward when I got it, but I kept getting a face full of exhaust, and the PO had apparently left it at just the right height enough times to blacken the FEL arm and cook a couple of hoses. Up, tall pipe, with a bend at the top to keep out the rain.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
I don't want to sound like a politician but I have both and they both work fine.
The Ford 1210 exhaust from the forward-facing stock muffler blowing back over me was an annoyance since I got it in 1992. When I replaced the rusted out stock muffler last year, I couldn't find an identical replacement. A small Cherry Bomb muffler from Advance Auto, couple weld pipe fittings, scrap pipe, exhaust flapper from TSC, some shop time and it now wears an upward-facing exhaust. The little tractor is much more pleasant to operate. Should have done this 20 years ago.
The L3200 faces forward. The exhaust never bothered me with or without the cab. Maybe it shoots the exhaust out a lot lower than the operator's head than the Ford did?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I turned mine up on my B7100 and added a short stack with a flapper to start with then later changed it to a 90 because I got tired of hearing the flapper rattle all the time.
Buse
B6100 with FEL
Oct 3, 2011
40
Sweden
I will have it fwd every day in a week. When I moved in to were I live, the previous owner of the house had an old MF with a huge black spotin the garage cieling.
This is just one of the reasons why I will keep the muffler forward to keep my nowadays (almost) white painted cieling. Also, I think I have the noise further away from my ears...
Just my 2 cents.
philztoy
L3830, IH695, Deere 4720Cab 3720Cab 4320 4200 450C 790, R Z and Jetstar Molines
Dec 1, 2014
96
Low forward out the front or really high upward. One of my tractors had a low upward (ROPS Height). It just buried me in exhaust. I ran it up 8 feet or so and hit a branch with it. But it is so nicely sloped back and behind me after it bent back that it is a beautiful thing.
olthumpa
L275
May 25, 2011
1,505
Maine
If you aim the Silencer forward and then you backup, which way is it pointing then :eek: :confused: :confused: :p :D
If you aim the Silencer up it will always be pointed up - unless you roll it over:eek: then it really does not matter.;):)
What does that do for your stats? :p:D
5,517
OHHHHH your talking about a muffler:eek:,,, I though,, OH never mind:rolleyes:
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
My previous two tractors had front pointed exhaust just outside the hood. I liked that this setup took the worry of catching a limb, etc. from happening. I do a lot of mowing in and around trees so a long vertical pipe is a liability. Occasionally I'd get a whiff of fumes if the wind was just right.
On my new M5140 there wasn't an option for a side/front exhaust pipe. I could have had something fabricated, but decided to try a shortened version of the standard long vertical pipe. We took about 18" off the top. So far it's worked well with no exhaust fumes noticeable. I still have an original pipe in case the shortened one doesn't work out.
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
I finally got my B2150 to a point where I could use it a fair bit this last weekend, even though the "dash" is still not together. I really liked the vertical stack that goes up about even with my canopy (on the ROPS). It's on the left side, and I turned the end bend to eject up and to the left.
The B7100 that I still have and has seen me through the long down time of the B2150 has the exhaust pointed forward. Sitting mostly still, it doesn't really matter. But most of the time I'm moving forward (or back and forth) at a relatively low rate of speed, and that low exhaust leaves me feeling like I'm choking. I do NOT like it horizontal and forward, but if I went vertical it would need a longer pipe to get it above my head. At that point, being hot gas ejected rapidly upward, it should rise and carry away. Indoor storage and painted garage ceilings not withstanding...
