I've been to several steel shops and the largest pipe I've seen is 4". Dorothy said there's no place like home.For a curved blade you could cut a section of steel pipe lengthwise.
I'd have better luck finding a box blade! Water heaters here are the little wall mounted on-demand type.If you want curved think water heater!
That still is not heavy enough steel for the cutting edge.
Go to the road dept and get a used cutting edge from a snow plow.I'd have better luck finding a box blade! Water heaters here are the little wall mounted on-demand type.
Don't see why I can't have a straight blade with a removable cutting edge, that way I can pull or push with it.
Hi several years ago I built a angle blade for my Bx2660, it's 6ft wide. For the moleboard I found an old piece of 1/4"X10"X6' flat had a guy with a brake form a slight bend in it, then I scrounged a blade off an Olympia ice machine 84" cut it down and bolted it on. Check around and see if there's an ice arena in your area they discard them when they become too short but they still have lots of material on them for what you'll need. I know that finding this in your area is like looking for hens teeth but they are really dangerously sharp and seem to keep there edge. Good Luck with your build BarryOver here a box blade is a new concept so I'm trying to design one. I've found a couple of fab shops that can do it "if" they have plans. I've found some plans and pics but I'm not sure what size my tractor will handle. Ideally it would be about 4ft in width as that's about the wheel-width of my tractor. HELP!
You're kidding, right?Go to the road dept and get a used cutting edge from a snow plow.
Thanks skeet, I'm gathering all the info I can.Ya know somebody a while back posted some pic of his rear blade he modified to a box he added a couple brackets along each side of the blade and bolted side plates to them and a piece of was either square tubing or angle welded across the top to keep the sides from flexing,,, don't know it that helps or not
I think he means for use as the cutting edge, but, anyway get much snow there, this week?...You're kidding, right?
Actually, he's not. My father got 2 used edges from the County Road crews, they just scrap them anyway.You're kidding, right?
