Another rookie question
mickeyd
Mar 21, 2014
1,192
Guin, AL
Have the valve stem down at 6 o'clock and let some air out. It will be liquid if it is filled.
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
That's the first step, second step is to rotate tire back to 12:00 and clear valve of whatever came out at 6:00.
Ron
2,559
How do you know if you have ballast in your tires?
IF you do, as was described, clear the valve - and you can find out how "full" by either a "sweat" line or by turning the tire and checking the valve again. If "full" you should be right at the top of the rim, so about 2 or 10 o'clock
jd57
L225, kingkutter 4' bushog,A&B 4' boxblade
Dec 14, 2014
38
hilham,tn.
Ok guys did what you said,no liquid. Next question,i have a Kubota L225 compact tractor,mainly going to be used to bushhog 6 acres and groom a 750' gravel driveway,should I put ballast in the tires?
A.O.
L3540HST LA724 FEL
Feb 6, 2015
120
South Carolina
If its flat and level I would say no need..
2,559
I would say yes.............go to walmart or tractor supply - they had windshield washer fluid for $2 gallon. The valve will cost you less than $10 - you are going to need about 20 gallons per tire, sounds like a lot of money , but it is the best insurance you will ever have!!! you will be adding about 320lbs total. The difference is ....well, you will see! :)
jd57
Dec 14, 2014
38
hilham,tn.
Thanks 85 Hokie. When you say "the valve" that's to put the fluid in correct? What about a pump? Sorry im brand new to this and know nothing!
I pulled a link of this site on how to do it and need to re-read it to make sure im clear on it.
