rear snow blower for b7510dt
jim194713
rear mower,fel need rear snow blower for b7510dt
Feb 3, 2015
pa.
Looking to buy a new or used rear snow blower for my b7510dt. I need the fel but am looking for info on rear snow blowers, any advice would help, I live in n.e.Pa.
OldeEnglish
Jul 13, 2014
768
Western, MA
If your looking for used, check craigslist in a max radius you will drive to buy one.
If you want to go new, check with local dealers.
With 17 HP PTO I believe you will be between a 4' and 5' width. Others on here could give you better feedback on that.
My 4' Loftness calls for 15 HP minimum but works great with 13 on deep and fluffy snow.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum.
b12
44
Maine
Does your B7510 have the hydrostatic, or geared transmission ?
Is snow blowing distance important ?
Larger diameter impellers will throw the snow farther, because the impeller blade tip speed is faster.
And 4 blade impellers are better than 3.
Two years ago I bought a used Frontier SB1164 rear mount for my B7800 HST.
The blower has got a 24" diameter impeller and it will throw snow over 35', I've actually measured it throwing snow 38'.
Frontier also make a SB1154 RM which I believe would be a good size for your tractor, it also had the 24" diameter impeller.
I am not sure if it's still true but Frontier and Blizzard rear mount snow blowers are the same blower, only difference is the Frontier is green and the Blizzard is red and they were or maybe still are, made by RAD out of Canada who is a big manufacturer of snow blowers.
Here is a link the the Frontier snow blower
https://www.deere.com/en_US/docs/pdfs/frontier/DSFE51007_frntr_snowblwr_3pt_v2a_lr_sngl_pgs.pdf
