Tie down Plate for front of M5140
9,623
if you are toting a chain with larger than 3/8 links......well you must have a tank with treads!:D
1/2" OR 5/8 Links on mine I do believe, Yea I know over kill, It's a proof chain that is used to pull thing like a Cat or yea a small tank. :rolleyes: ;)
But I'm pretty sure I'll never break it.:D
2,897
Them thar chains too heavy for me to pick up !!!! :D:eek::D:) Throw them over my shoulder and I tend to lean to one side!:):)
8,772
We got a 5/8x20 footer at the shop for when someone makes an oops with our ten ton forklift. Usually have to wait for a semi to drop off some freight before we can get it un stuck.:rolleyes: If your lugging one of those around in the woods, your more of a man then I am. Our big joke about that 5/8th chain is it "takes the man" out of you.
Your right about it not breaking ;) I've seen it bend the I beam on the back of a step deck trailer that's designed to keep vehicles from running under the trailer :eek: We ended up having to call a semi wrecker that time :rolleyes:
Tallahassee Kubota Man
M5140HD/LA1153/LandPride RCF2072/DirtDog disc/RakeMaster grapple/Caroni tiller
Thanks North Idaho Wolfman, makes sense on the direction of the D ring install.
I've had to pull my truck and trailer out of the mud in the past... (10K +) so got a weld on D ring with 15K working capacity.
Thanks for the ideas and photos everyone! This group is a wealth of knowledge.
Finally got my front plate finished. The D ring is 4" and the plate is 1/2 ". The fabrication shop did a great job rounding off all the edges and the holes for the bolts were spot on. A couple coats of primer and Kubota orange and viola! The hardest task was holding the plate and the FEL guard in place so I could get the first bolt started. That there steel is a might heavy!
Orange Turbo
MX5100, pto13000kw, Loader, Ripper,Plow,Disc,Mower,Forks,3pt spreader,Box Blade.
Feb 2, 2015
175
Mo
Sweet!
I like, looks factory.. Nice job.
