Some people were wondering about fixing wallowed out holes on a back blade. Here's a perfect example. The holes were wallowed out so bad, that when it was in the straight position, it would rotate side to side around 30 to 35 degrees. Put it in the 22 degree slot and it would rotate almost 60 degrees. Made it interesting when grading. When I disassembled it, this is what I found.
Top side
Bottom side
The sleeves for the pins had rusted out and had welds break.
Sleeve
I dug around my father in laws shop and found a couple pieces of schedule 40 pipe with the right inside diameter to sleeve the holes for the shaft and angle pin.
Drove the pipe through the existing holes with a BFH
I drove the pipe through leaving 1/4" sticking out the other side to allow some room to weld around it. Filled in the the gaps, and ran three thick welds around the pipe. Then, ground it down some for clearance on the bottom side.
Top side
Bottom side
Sleeve
