Fuel Cock Position L3250
p.rizzi
Kuboata L3250, Case 1835B, Chevy K3500 4WD Dump, Eager Beaver 5 Ton Equipment Tr
Jan 29, 2015
Hudson MA
My manual shows 2 "on" positions for the fuel cock on the fuel filter assembly. One is in the vertical, the other is rotated fully counter clockwise. The manual does not address this. Does it matter?
6,436
Nope it doesn't matter witch position.
The 2 position setting is a left over from when there was run and reserve on the tanks, but with a diesel it doesn't work, dry is dead (air locks the injectors) and flipping a lever to give it more fuel is still dead. ;)
p.rizzi
Jan 29, 2015
Hudson MA
I pulled fuel filter assembly tonight and placed the fuel cock lever in each position. I only got drips of fuel. Bowl is not filling.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum. Did you check the line to the filter?
6,436
What he said!
Check the input line to the filter for flow as it may have a plugged fuel tank outlet.
p.rizzi
Jan 29, 2015
Hudson MA
Thanks guys. I'm going to work on it again tonight. I thought I might drain the tank and check for crud with my inspection camera.
p.rizzi
Jan 29, 2015
Hudson MA
So, I gave up and had my machine hauled to the dealer. First time it has been in the shop in the 14 years I've owned it. Turns out that there was sludge in the bottom of my fuel tank. Fuel pump needed replacement. Also, fuel filter housing was cracked. Front axle seals were leaking. All fluids checked out OK. Should be a reasonable repair cost. Original tires are dry rotted pretty badly. I got a quote of about $1,500 for a set of R4's. I will have to shop around to find R3 or R4's that will replace the obsolete metric sizes of 8-16 fronts and 13.6-26 rears.
