Thanks for the book website that will come in handy but my problem is there are no marks on bottem crank gear at all no dots so where do I put the crank at then line all other dots up most engines time tdc compression stroke but ive also came into some that time before tdc and this my be my problem.
TDC= Top Dead Center Piston at its top of travel
Well, if you have #1 at TDC on compression, verifiable with a dial indicator, then the book should tell you either before or after TDC and you can set the crank gear at the right degree for the timing, lining up all the other marks appropriately. TDC on compression is usually what sets the crank gear at a known position, but it is nice when they mark it for you. You can also check the back side of the crank gear, someone may have put it on backwards.
You can only be a few degrees off one direction or the other. If you are more than that it won't start or it will run-away on you (So keep some kind of air choke device handy in case it starts to run off on ya)
Thank heavens I've only had to time diesel motors a few times and it's nerve wracking every time I do it... pun partially intended!
