I have a l3800dt can I leave my block heater plugged in all day so it is ready to go when I get home or should it be set on a timer?
You can leave the block heater plugged in all day but will add to your hydro bill. We used to leave the block heater in on one of our fire trucks plugged in all the time and it cost us about $3 a day about 10 years ago so about $90-$100 month. we geared up a timer so it only ran a few hours a day say 1 hour on and 3 off but was also in a heated garage. The only reason we plugged the heater in was to reduce the smoke from the exhaust. So you should be able to try a timer set for about 2-3 hours before you plan to use the tractor, our new Kubota l3901 does not have a heater just glow plugs. You will just have to play with the timer to see what works best when the temperature is milder you should be able to get away with less time heating and maybe more in the lower temps. I hope this helpsI have a l3800dt can I leave my block heater plugged in all day so it is ready to go when I get home or should it be set on a timer?
Cathy,Thanks, we would only plug it in on days when we know we will need it that night after work. I need a new timer and wanted to make sure it was not an issue.
