Dry Rot
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
I've got a dry rot problem with my front tires. Any suggestions on how to keep it from getting worse?
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Tomcat
Nov 19, 2014
557
Thailand
Thanks Coach. I was thinking of packing the cracks with silicone but wasn't sure how it would work.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Those cracks don't look real bad yet. The ones that are of concern are the ones that head around the shoulder of the tire, into the sidewall, parallel to the cleats. Eventually the crack gets big enough to pinch the tube, from that point, it's a blow out boot, on the tire, and an old tube sliced down the middle inside, next to the stem as a shield. Gemplers catalog, or a good tire man can get you tire parts you never knew existed...
Tomcat
Nov 19, 2014
557
Thailand
Spent some time on the web and found a suggestion of using the black goop used to install windshields. Might be a trick finding that here!
8,773
Got any rubber trees? We had one by the garage when I lived in florida. The damn leaves would glue them selves to the car when they would fall :mad: borrowed a neighbors chain saw and cut it down. I'll never do that again :rolleyes:. Sap was like pine pitch on steroids. No wonder a tree service wanted a grand to get rid of it. Had to throw out the clothes I was wearing, and took a week of scrubbing to get the crap off my arms. Not to mention, 4 hours cleaning the saw, and having to buy a new bar and chain.
If you had one of them, you could probably line the inside of the tire with pitch, and it would probably be close to that window adhesive.
andmel
L2850 / L3901 LB / G1800
Dec 17, 2014
50
concord, VA, USA
Based on Anthony Hopkins in the movie,"The World's Fastest Indian", lots of black shoe polish hides cracks pretty good. ;)
9,642
Big cash crop here but quite a different tree as the ones grown here are tapped for latex.
Tires were originally made with latex rubber, White walls were pure latex.
You could in theory get some latex and distill it down and recap your tires! :rolleyes:
But Please quit messing with the shot, worn out, dead tires and buy some new ones already! :cool:
Tomcat
Nov 19, 2014
557
Thailand
I'm not trying to fool the safety inspectors at Bonneville, just trying to save some coin on new front tires :)
BravoXray
BX-25D, Ford 9N, Bobcat 825. Too many implements to list
Feb 6, 2014
190
Lake Winola,PA.
Keep the sun off of them. It's the easiest and cheapest way to keep them from getting worse. Some skid steer owners get their tires foam filled, I don't know if that's an option where you are, but it may be cheaper to buy new tires. If you don't have a loader on the tractor they might go for quite a while yet. Some of the farms around here run them looking a lot worse than yours.
Beer versus tires? Beer!
Jerry
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
Just a thought....polyurethane construction adhesive. tough water proof bonds to just about anything. and reasonably priced.
Tomcat
Nov 19, 2014
557
Thailand
I'm not planning on any hi-speed running so will run 'em as is for now. No problems with the rears. Hopefully heading to the Big City next week for some much-needed supplies. Only one "store" here and they only sell oil and grease. Will update on what I do. Yes Jerry, BEER!
