Factory PTO spline cover
mdhughes
L3901DT
Dec 10, 2014
1,351
1,104
Ste Geneveive county, MO
My L3901DT came with a plastic looking cover on the PTO spline from the factory and was wondering if it is a good idea to leave it on or take it off? I don't do a lot with the PTO and was wondering if the splines will rust with the cover on it? I haven't taken it off yet so I don't know if there is grease on the shaft that would help protect it or not.
2,858
I would make sure that it is well coated in a oil film and rubbed down and keep it covered. Does the cover have a weep hole in the bottom ?
rk1475
L3800HST,FEL,WT Box, R4 Tires, WR Long Grappler, Landpride Brush Hog, Snow Plow
Feb 25, 2013
10
Brimfield,ma,USA
I have an L3800. The manual says to leave it on when not being used. Mine is covered with grease, so leaving it off would subject it to dirt.
6,864
Older model of tractors came with a piece of clear tubing cut to length to cover the splines.
Could go to your local hardware store and buy 6" of tubing that fits snug. Don't need the end covered, it's just a protector.
mdhughes
L3901DT
Dec 10, 2014
1,351
1,104
For reference, here is the section of the manual that talks about leaving the "PTO shaft cap" in place:
Thanks to rk1475 for telling me that it was in the manual, I should have know better to look there first :eek:
