coachgeo
Planning to rent a box blade Sat and seeking some advice.
. Banked curve needs repair. What should be the high side (outside of curve) via drainage is the low side. After repair I plan to put in a guide to make it drain differently as suggested by things I've read on road maintainance (Belt Diversion Pg 41 of http://www.fs.fed.us/t-d/pubs/pdf/11771802.pdf ) Looking for suggestions on how to best use the box to reset the bank to what it should be for later belt diversion sited above.
. Gravel is massively impacted everywhere. Basically it is Two Track gravel in some parts and just packed gravel with bad pot holes in others. Assume I'll have to just box it, rebox it, and box over and over all day long. Open to suggestions.
. worst pot holes are where the gravel meets the road. Where cars stop. Braking points over and over, then rain fills the brake spot. Car brakes same area in wetness and moves stuff out of previous brake stop pot hole over and over till spot is now big pot holes. Again looking for suggestions.
I'll have a back blade available too.
Think the rentable box blade is a 4 footer but might be 5.
Tractor is L225
Tractor is L225
