will these work on a 93 b7100 {4 tires on Kubota rims fronts are 6-14 on 6 bolt rims rears are 9.5-24 also on 6 bolt rims }-
The 7100 calls for a 6-12 front and 8-16 rear ag tire. Do some searching on here, there are a bunch of threads that will answer all your questions. For the basic tractor info click the linkwill these work on a 93 b7100 {4 tires on Kubota rims fronts are 6-14 on 6 bolt rims rears are 9.5-24 also on 6 bolt rims }-
Way to go Wolfman glad to see you're using the numbers and formula to show them how it's done.Not if it's a 4wd, ratio is wrong and you'll just break 4wd components.
If it's 2wd the might work, check the bolt pattern because they change between old and new and different models.
RC = Rolling Circumference
Ag
6-12 RC 69
8-16 RC 93
=.74 ratio
Turf
6-14 RC 72
9.5-24 RC 119
=.60 ratio
Ag
6-14 RC 75
9.5-24 RC 123
=.60 ratio
Are the rims bad or do you just need new tires? Searching for a used set without knowing before you start is a waste of time really because the wrong thing will break your tractor ( most Kubota's don't share the same bolt pattern anyway so the rims won't fit or the offset is wrong etc ) and you'll be spending big bucks to fix AND have to end up buying the correct tires new when all is said and done.been looking for the rims and I just cant find anything any help please be great
