Hydraulic adjustments
nykubota
B2320 FEL MMM, snow pusher, BB, brush hog, carry all, pallet forks, QH, QA.
Jul 17, 2014
Upstate NY
Couple of questions here.
Is there an adjustment to slow down loader motion? LA304 is actually a bit quick going down, and I could use little more controlled motion here, especially with loaded bucket.
Can a hydraulic bypass be adjusted little higher? Say, I am trying to pick something heavier with forks, and it is enough that the tractor won't even curl the bucket under load, but I can tell the motor is not even being loaded at all. Giving some more RPM won't make a difference.
Tractor: B2320.
Thank you!
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
The main control should let you ease it down like it was a feather. Are you stating that when you barely engage the lowering control it just zips down like it has no speed control?
9,648
Most loader valves do not have any adjustment for down speed, it is purely a matter of how far you move the control lever.
If it was an ongoing need to keep things slow you could add a regulator to the line and regulate the flow. ;)
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
I agree with the other posters. Move the valve a little and you can make it drop very slowly. Slam it over and it drops like a rock.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,275
177
Coyote Flats,Texas
Back when I owned a M4900/LA1002 I installed an adjustable flow control valve to slow down FEL boom lowering when handling rd bales. Before installing flow control valve FEL control valve was difficult to feather with a heavy load on the loader.
nykubota
Jul 17, 2014
Upstate NY
Thank you guys. It seems installing a flow control valve is a logical step. I will look into that. Lack of experience may be another contributing factor. :eek:
Cheers!
BotaDriver
L3800dt
May 15, 2013
326
North GA
Cheers!
Be sure to put it in the right spot. Do not put it after the FEL valve!
