Question for everyone out there. Looking at a quick change set up for the 3 point. Looked at the Pat's system, as well as the standard 1 piece plate. Any advice? Pros and cons? Thx and God Bless
That's sweet the PAT's method. Been brainstorming on this too but my idea required modifications to the implement too. This is way better. Each Pat works sorta works like a Ringfeder type hitch.Question for everyone out there. Looking at a quick change set up for the 3 point. Looked at the Pat's system, as well as the standard 1 piece plate. Any advice? Pros and cons? Thx and God Bless
Pipewelder,Question for everyone out there. Looking at a quick change set up for the 3 point. Looked at the Pat's system, as well as the standard 1 piece plate. Any advice? Pros and cons? Thx and God Bless
So you shortened your fabbed lift arms the length of the Pat's like connects keeping the over all length the same?I bought a pair of quick connects. Upon moving things back, a couple shafts end up too short. My three point wont carry as much. My solution- make new lift arms and weld connects on the outer ends.
So far its working out good for my needs.
Hi Pipewelder we have 3 Bx's with quick hitches, the one thing that you have to do is make all your implements adaptable which is usually adjusting the top link bracket. Once you've done that it only takes a minute to switch implements and with some (without PTO shafts) you don't even have to get off the tractor. They will also move your implement 4" back so before you buy make sure your drive shafts are long enough. Now that I've used them I wouldn't be without one.Question for everyone out there. Looking at a quick change set up for the 3 point. Looked at the Pat's system, as well as the standard 1 piece plate. Any advice? Pros and cons? Thx and God Bless
Yes,shortened the arms. Was necessary in my case.So you shortened your fabbed lift arms the length of the Pat's like connects keeping the over all length the same?
