L3030 ignition switch won't turn off engine
TexasBill
L3030
Oct 19, 2014
Arkansas
When I turn the ignition switch to the off position, it will not kill the motor. I have to use the kill switch to shut the motor down. Any suggestions on how to fix this?
OklahomaBill
B7300
Sep 17, 2014
17
Oklahoma
That's what the engine stop knob is supposed to do... At least it does on my B series 7300.
Yours may be different TexasBill from Arkansas.
7,703
TexasBill, on a diesel engine you starve it of fuel to terminate it's ability to run! Turning the start switch to a different position does not effect the fuel supply. Pull (or push, as required) the fuel shutoff to stop the engine.
ipz2222
L235, bx2670
May 30, 2009
1,927
34
38
chickamauga ga usa
Blown fuse is what caused mine. There's a solenoid stop valve that shuts the fuel off, if it gets no power (activated by turning the key to off), it will not shut the fuel off.
11,237
Fuel solenoid failure or the circuit that feeds it, probably via a fuse and a timer relay.
Locate and check fuse.
Locate the fuel solenoid on the injection pump and disconnect the feed line and attach test light to the feed wire turn the key on then off and the light should light for about 8 seconds.
OklahomaBill
B7300
Sep 17, 2014
17
Oklahoma
I pretty much learn something new here everyday.
Thanks
Okb
