T TexasBoy Member Equipment Kubota M7060 HDC12 & L4600DT Dec 11, 2013 118 10 18 Central Texas Oct 17, 2014 #1 Anyone know the fluid capacity of the front axle on the L4600 4X4 ?
D Daniel262 New member Equipment 2013 L4600HST, landpride mr1572box scraper, woods rotary blade , johndeere forks Jul 6, 2014 13 0 0 Burlington, WI Oct 17, 2014 #2 My manual says 6.9 U.S. qts.(6.5L) and mine is 2013 l4600 4x4. It also specifies super UDT-2 OR 80w90 gear oil. I am not sure which I will use ,still have to read some more on it...
T TexasBoy Member Equipment Kubota M7060 HDC12 & L4600DT Dec 11, 2013 118 10 18 Central Texas Oct 17, 2014 #3 Thank you sir !
T TexasBoy Member Equipment Kubota M7060 HDC12 & L4600DT Dec 11, 2013 118 10 18 Central Texas Oct 19, 2014 #4 After draining both sides, the axle would only take about 6 quarts to refill it.
D Daniel262 New member Equipment 2013 L4600HST, landpride mr1572box scraper, woods rotary blade , johndeere forks Jul 6, 2014 13 0 0 Burlington, WI Oct 19, 2014 #5 TexasBoy said: After draining both sides, the axle would only take about 6 quarts to refill it. Click to expand... What kind of fluid did you use?
T TexasBoy Member Equipment Kubota M7060 HDC12 & L4600DT Dec 11, 2013 118 10 18 Central Texas Oct 19, 2014 #6 Daniel262 said: What kind of fluid did you use? Click to expand... Kubota 80-90 gear oil in 2.5 gallon container. Part Number : 70000-10502 Kubotas price isnt much different than all the rest out there so I try to buy from my dealer.
