Broke my new BX
Mr Orange
NJ
I have had it for a few weeks now. I broke the hazard light. I was mowing and I guess the bush i was next to broke it. I didn't hit anything. I mean anything I hit, also hit my body. A little disappointed that it broke so easy. it is all plastic. Off to get a new one.
2,543
IF the is a possibility for repeating that , make a set of guards like WILDFIRE made......
If paul reads this post he can direct you to his video - I cannot find it .!
2,543
3,297
OK I have busted a couple as well sooo I took them off and moved them to the INSIDE of the bracket on the ROPS, havent broken one since
t33jetman
BX25D, TLB, 1860 bal. bucket, Curtis Hard Cab
Aug 31, 2013
212
Wooster, Ohio
the metal guard around the light has a hole in it where the bolt passes through to connect to the original location on the ropes
take the light off put it on a block of wood trace it the outline around the block and then cut the wood out and use that as a template to bend a piece of metal around to match the shape of the light then drill a hole in it to make where the bolt will pass through and then bolt t it back on the bracket
Highspeed
B-series
Jan 27, 2014
26
mid-Michigan
You didn't by chance get the optional 'bush removal device' that extends past the front of the tractor did you? Guaranteed to solve the problem for good. ;)
Mr Orange
NJ
I do. But these bushes are huge. and not mine. besides without them, I would be able to see the neighbors house. I like not being able to see neighbors.
