aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
So what could leak, cross over mix or what ever to make my UDT oil get milky looking and smells very badly like hypoid differential lube?
The fluid was low when I got my tractor so I got some Kubota UDT oil which is the right stuff. Now after using this tractor for the summer the trans oil smells bad. Is there a gear case that could crack and mix fluids with say the rear planetary axles? Are they supposed to be the same UDT or are they something different?
Unless there was the wrong fluid in the trans when I got it something has happened so I wanted to pick your brains to see if someone has a quick answer to this problem.
I know I will have to drain this gook out and refill with Kubota UDT but I don't want to waste the money of there is something else to fix.
