I have an L345DT that I recently purchased, and everything works, except for the PTO. I have the 2 stage dry clutch, and when I try to engage the PTO, it grinds really bad. I have adjusted the clutch according to the manual, and that helped with overall usage (it was WAY out of adjustment), but the PTO won't engage without grinding.
The other problem is trying to use the low speed on the PTO. When I try that, I get a couple of "thunks", but then nothing. Are the gears bad for the low speed PTO?
Thank you in advance for any help!
