Hi wondered if anyone could please help me with this problem before I have to take it to a garage.
Kubota B1400DT grey import from Japan. 800 hours. New oil filter, new air filter , new fuel filter. Before winter I had a leaking seal on the PTO, local garage fixed that , when I tried it when I got it back the PTO didn't work at all. Garage came out and found a connection pin inside the transmission had snapped off. Tractor worked fine. Did some ploughing and rotavating and then stored it outside but under cover for the winter. Just tried to use it today. It starts fine, idles fine , revs fine. As soon as you either take it for a spin or try and get it to do any hard work the revs die off and it trys to stall unless you drop the clutch and take off the load. Stalls even quicker going up hill ???
Looking at this forums excellent resources I think you would know my tractor as a Model Kubota B6200,Series B Series,Engine power 15.0 hp,PTO power 12.0 hp. It' a grey import.
