tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
EDIT: SORRY ABOUT THE WHOLE PHOTOBUCKET ISSUE. YOU CAN VIEW SOME VIDEOS ON MY CAB AT MY YOUTUBE CHANNEL: https://www.youtube.com/channel/UCbqPkeqZrlHPnxgejb-xMQg?view_as=subscriber
Hello, My name is Tom and I have a 2012 BX1860 that I purchased new. I have almost 200 hrs on it using it year round on my property. Last winter was my first winter using it for snow removal on my 500 ft driveway and I froze my arse off!
No problem, go buy a cab right? WRONG....$4,000+ are you kidding me? I'm way to cheap for that...I have a welder and below average welding skills ...how bad could it be
Well here we go. Starting from scratch with anything is always a nightmare and this has been no exception but it's coming together piece by piece. I wanted to post this in the hopes it may help others with ideas on how to begin the daunting task of fabricating a cab.
I didn't want to drill a single hole in the tractor but wanted to be able to easily mount and remove the cab. I decided on a bar that mounts to the ROPS bolts and stay's on the tractor. The cab will sit on the 3/4" studs and are locked in place by a pin and retainer.
For the front mount, I welded up a bracket with two suds that drop into the existing mounting holes for the front of the floor.
Here's the mounts (aka 3/4" x 4" bolt) inside the rear uprights
Started to build the cage off of these mounts.
Cage is done!
Built the doors with pin hinges so they can be removed in seconds.
Skinning the doors with reinforcement/mounts for the windows.
Coat of orange paint and carpeting on the doors and headliner to absorb noise.
Doing some electrical and interior work. Mounted the fan, windshield wiper and heater.
I will keep updating this as I continue to make progress. I have all the plexiglass installed, control panel for the worklights/heater put together and mounted and just ordered safety glass for the front window. I don't have pics of that yet, but I will soon!
Cage is done!
