Just checking to see if anyone out there happens to know the part number for a B7200 brake shaft oil seal. These are dry brakes...supposed to be. Ordered a new one from local Kubota dealer, and after a week of waiting, found that it was not the right part. You can see the pictures of the shaft with the original seal, then the new seal hanging on the shaft. I think it's a little loose.
Also, while I have this apart, and will soon be draining fluid, what transmission fluid works in the gear drive B7200? I've read a lot of posts about the "Super UDT-2" oils, but it seems they are more suited for hydro trans. What do others with similar models use?
thanks
thanks
