Wanted to buy finish mower for B6000
djmc35
4 Kubota B6000's, Cub Low Boy, Sears tractor w/FEL
Jun 19, 2014
79
Bloomington, IN, USA
Wanting to buy small finish mower that turns counterclockwise. My B6000 has an 18 spline PTO. Not 10 as are some. Here is a picture of the tractor pto and thehttp://www.orangetractortalks.com/forums/attachment.php?attachmentid=12431&stc=1&d=1407816877 tractors bolt on tiller. I also have a 3 point hitch setup with a 1 3/8" shaft adapter. Let me Know what you have. I live in Indiana USA
2,913
I am with Eric , easier to find and opens a lot more doors for more goodies later:D !
9,753
Getting a reverser along with giving it a normal rotation it will also give it a normal PTO spline. ;)
djmc35
Jun 19, 2014
79
That Reverser Ideal sounds great! But; I have had no luck in locating one? I have found 10 spline reversers but no 18 spline Reversers. Please let me know if you have one. I have an adapter to change the 18 spline to the standard 6 spline 1 3/8 shaft. All I need is a 48" Mower that turns counterclockwise or one that can be converted. Looks like someone with a b6000 may have already done this. Thanks for the suggestions. djmc35
djmc35
Jun 19, 2014
79
Well I found a Hub City PTO Reverser 10 spline hooked to a B6000 with a 10 spline shaft so I bought them both. It needs TLC and it will be good to go! Thanks again! djmc35
