PTO engagement
blkfl1
bx2370
Harvard IL
Re BX 2370
So at what RPM should I engage the PTO?
It seems to engage soother at higher rpm's!
Is it harder on the clutch?
I see nothing in my owners manual.
Thanks
BotaDriver
L3800dt
May 15, 2013
326
North GA
Re BX 2370
Thanks
Slightly over idle. Once engaged, throttle up. It's in every manual I've seen.
3,035
Re BX 2370
Thanks
When I bought my Bx - I would engage the PTO at high throttle, didnt know I was doing it wrong till someone here asked the question....
now i throttle down, engage and then ramp up .......
harder on all moving parts......think about asking your body to get to full speed without getting up to speed.:D ( ok - a cup of coffee, a newspaper....)
Something that is going to spin at that rate needs to get to speed slowly
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
The way my dealer showed me how to engage the PTO was to rev it to over 1500 rpms, then basically slam the lever forward. Made the whole tractor jump to get the bushhog spinning quickly.
I did not like that method because I imagined the strain put on the drive system.
Now what I do is put it maybe 12-1400 RPM's and slowly ease into the drive lever, kind of like letting out a clutch. I bring the cutter up to speed, there is no shock to the drive system and I feel it is a better way to engage it.
How do you other guys do it?
TripleR
Sep 16, 2011
1,911
SE Missouri
I engage/disengage at fairly low RPM 1500 or so then spool up to operating speed; spool back down to engage.
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
I have a L3200 HST, I use the clutch, when I engage the pto. I bring the rpm up to a min of 1200 rpm. Push in the clutch, move the pto lever, then let out the clutch, feathering it. This a good idea as I've had junk in the tiller before and kept from having a shock in the drive shaft, due to junk preventing the tiller from rotating. Just a holdover from using a old deer.
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
I have an HST and this is my first tractor so the clutch and engaging the PTO sounds a little foreign to me. If it's how I think it works, your mentioning of the clutch is similar to me slowly engaging the PTO lever at a low speed then once engaged bringing the engine speeds up.
3,035
Somewhat the same idea, just one is gear driven and the other hydraulic driven - same thought process. Slow and easy does it
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Depends on what implement I have on has alot to do with how I engage the pto. But in general the lower the rpm's the better and engage it slowly.
duck
14
georgia
at idle speed and then ramp up rather slowly. 10 foot bush hog and an eight foot tiller. btw the tiller I run in 4x4 cuz it wants to push.
