After finishing tilling yesterday, pulled the tractor in the shop, and the key would not kill the tractor…..so I pulled the "engine stop knob"……killed the tractor. Then will the engine stop knob pushed in, I tried to start the tractor, and noticed no dash lights were on, and the engine would not turn over.
I went to check the battery and noticed that my hold down bracket had come loose and let the battery shift to the side thus wearing through the insulation on the hot wire of the battery and allowing it to arc against the metal support near the radiator.
I check all the fuses, including the slow blow fuse, and all appears to be fine, however issue remains: no dash lights, and will not crank.
Any/All thoughts or suggestions would really be appreciated!!
