Todd,
One other important tidbit is to remember is everything should be clean enough to eat off off. Cleanliness is super important. Make sure you've also cleaned out the crank passages before reassembling. Any gunk in those passages will end up carving away at the bearings.
Also, DO NOT USE SCOTCH BRIGHT TO CLEAN ANY INTERNAL ENGINE PARTS!!!! It might seem like a great idea but it's not. I can't stress this strongly enough. The Scotchbright fibers can get into stuff and can create a real mess. If you did use it, you really need to be 100% sure that the parts have no fibers left on them. You can always wash the block and parts with Dawn dish soap and water if necessary to make 100% sure everything is spotlessly clean. Better is solvent if you have access to clean stuff but whatever you do just make sure everything is clean, clean, clean... Did I mention stuff needs to be clean????? LOL! Am I being clear here?
As Wolfman advised, make sure all of the assembly lube is cleaned from the back of the bearings and the top and bottom of the rods. I'd recommend using brake parts cleaner to make sure all of the assembly lube is out of there. You want both the bearing backs and the rods to be super clean and dry when you assemble them. Use plenty of assembly lube between the crank and bearings, but never on the back side of the bearings. Also, I'm assuming you Plastigaged after you cleaned both the bearing front and backs right? If not, you need to check it again once the backs and rods have been cleaned and dried. Assuming you did, glad to read things were in spec. As previously mentioned, you want the clearances right because it will affect oil pressure especially when hot so it's worth the time imho.
Rods and cap numbers match and get assembled on the same side when bolting together. Also pistons should have a notch or mark that denotes "front." That notch or mark needs to point to the front of the block. It's important because the rotating assembly is designed to rotate only one way. The rods usually have additional meat on one side to handle the stresses for the rotational direction.
Hopefully you have a shop manual as it will lay most of this out for ya and they have good pics.
We're here if you need us!
Good luck!
Steve
