Super UDT 2 or SAE 80-90 Gear Oil for Front Axle??
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
I just changed mine yesterday. I used 80-90 gear oil. Seems like a better solution to me, but I'm used to old iron.
Jan 30, 2014
132
Central NY
Yeah, seems like the way to go for me also, I am definitely "Old School" . . . . Probably won't get to it till tomorrow or Wednesday . . so plenty of time for others to weigh in . . Old Iron . . like the way you think 08quadram . . ;)
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Here's the deal from what I have learned with servicing Kubotas for quite a few years in VT, CT and NH. The 80w-90 will work to slow a leaky front axle and will safely lubricate your axle in most conditions. The UDT/SUDT/SUDT2 is more likely to weep by worn seals.
HOWEVER, if you live somewhere cold, you need to read this!
I have found that water (condensation) MIXES with UDT and forms a slushy mix, but it will NOT separate into oil and water as easily. UDT seems to emulsify and mix.
Gear oil will SEPARATE.....you will have WATER (ICE) in your lower hub/pivot assemblies. I have personally seen the ice freeze and pop the lower caps off an L48 tractor. I have also seen ice completely disable a machine. Once your front axle freezes, you need to wait for a warm day till you can move it again....no way a torch will heat it up.
SO......moral of the story.....both will work, but I would strongly suggest UDT/SUDT if you don't have a bad leak, to prevent future issues.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
I use the UDT. My B only takes 4 gallons in the trans/hydro.....so might as well use the rest of the pail in the front axle.
Plus cold days outnumber warm ones up here, so works for me.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I've had trans/hyd fluid in mine for years with no issues. No more than it gets changed price is hardly a issue if you break the cost down over the life of the fluid.
4,351
Hey if your doing the whole thing, your gona have SUDT left over so yup that's what I use
Jan 30, 2014
132
Central NY
Thanks a lot Fellas . . I did the Hydraulic filters and fluid change today, the engine oil and filter yesterday, I will do the front axle service tomorrow using Super UDT 2.
Thanks again. I love my L3800.
