My 2230 started acting up last winter (dieing like you turn the key off for a second or two and then recovering) when I was traveling to a snow removal job. When it first done this I thought it was a load of iffy fuel and just put some SeaFoam in the tank to rid it of moisture.
Well it's summer now and several tankfuls later it's still doing it. No rhyme or reason for when it happens.... straight & flat, a little hilly, sometimes bumpy, only now it's happening when deck is engaged & cutting, once maybe twice in a 2+ hour period where before nothing other then hystat was engaged.
I keep going back to the seat safety switch which I've cleaned an put dielectric grease on now. But when I start it and lift the seat to engage the switch, the seat has to tilt up quite a ways to kill the engine. I always wear my seat belt so I'm not bouncing on the seat to trigger it. So I don't know how it could be the seat.
Filters changed last fall and I've only got 23hr run time on them so I've kinda ruled that out.
Where else should I look?
