My grandfather bought a M5030su at an Ag auction last winter. The tractor was sold advertised as in good running condition. From the exterior, it looked to have been worked pretty hard, but is in solid condition. We have had plenty of issues with small things like hydraulic lines to the attachments, worn and leaky cylinders, and the other usual stuff.
The engine purrs like a kitten and cranks perfectly every time when the machine is cold. Everything works, and the tractor drives and operates exactly as you would expect it to.
After reaching normal operating temperature, the engine will seem to begin to not want to accelerate. It seems as if the engine wants to stay at an idle. You can move the accelerator handle or foot pedal but the engine will not revv up. If you move the accelerator all the way to slow, you the engine will
usually die out. As long as the accelerator is moved forward somewhat, the engine will idle. Nothing that I do seems to make any change in this condition other than letting the machine cool down. If you let the tractor sit for about an hour, it will crank and run perfectly again. Once it gets warmed up, but at no exact specific rate or time, this issue will always happen again. It seems that the hotter it is outside, or the more that we were to machine, the faster that the issue will present itself. The engine is running at a little less than halfway on the temperature gauge when this happens. Nothing seems to be overheated at all.
Sometimes, it seems as if you are able to keep the engine running at a fast RPM that it will stay revved up as long as you do not move the accelerator or cause the engine to go dead. If you allow the engine to lose its speed, it will become stuck at idle and you can move the thrall you want, but nothing is going to change until the machine cools off.
It really seems as if either the engine is not receiving any fuel even though the linkage to the fuel pump is moving, or that something is keeping the engine from revving.
I am definitely not a tractor mechanic, but can definitely follow directions. I am at a loss in this situation though, as I do not really know where to start. I have searched around quite a bit, and the only thing that I could even find that sounded similar was some guys talking about the fuel injection pump relay possibly being bad, but I am unsure of that.
Does anyone here have any experience with anything like this?
