Homemade Disk Drag
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
322
27
23
Mobile, AL
I made a drag for my 4' disk this weekend and it worked great. I bought an 8' x 7.5" wood post from TSC and cut it down to 6'. I Attached it with 2 pieces of 6' chain doubled over. I made sure there was enough chain to allow the post to be rolled on top on the disk for transporting. It really did a good job of leveling while disking and covered soybeans nicely. A few times where I needed more weight, I just rolled it on the disk, made a few passes, then rolled it off and leveled it in one pass.
uncle carver
L3200dt 4x4 industrial tires
Jun 20, 2014
terry,ms hinds
buy a sheet of 4'x8' section of expanded metal and another timber. cut it down to 6' . bolt it to both timbers(2" lag bolts with washers) and you got a humdinger of a harrow. You can also use a section of Cyclone fence between the timbers.
bambam31
Apr 3, 2014
322
27
23
Mobile, AL
Many of our plots are small and require some tight turning. Your design would probably do a better job than mine but then it would prevent me from backing up.
I'd like to see a picture of your rig. It may be something I'd like to add to my arsenal in the future. Thanks
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Great job on a simple solution to your problem!
uncle carver
Jun 20, 2014
terry,ms hinds
BtheAM BAM I don't have one but I have seen them used in horse arenas. Yes they would be a problem turning around. They are great for covering grass seed and dressing lawns for sod.
