Hi guys, first time tractor owner doing a first time post. First, I have an L2900 with loader and 370 hours. Has always ran great up until today when I really need it. Ran a couple days ago and no problems. Today I went to start it and it acted like my battery was dead. So I tried jumping it off and all my dash gauges came up fine including work lights and such, but when I go to start it he starter will try to turn over just a bit but not enough to start it. I checked the existing battery with a voltmeter and it has 12V, but when I turn it to start it drains it down to nothing. So, (thinking I had a bad battery) just used my jumper cables to piggy back off my truck and essentially put a different battery on it. Doing this all power comes back but when I try to start it it does the same thing....turns over once then nothing. After checking out the existing battery that is good, if I try to start it once it immediately drains the battery. I've read on here a lot about bad grounds but my ground is welded to the frame and I have good continuity to other parts of the tractor to my negative terminal. I took the alternator out of the circuit and no change. I woukdnt think I would have a bad starter bc it does try to turn over. It seems to me that something is going to ground and that's why I'm draining my battery. Any ideas?
