1000.00 B7300 HSD runs. But i have a question
redneckarchery
bx2230 fel,phd,bb,disc
Oct 18, 2010
45
blountstown,florida
I was using the loader to scoop dirt and i guess the load was a little too much and it stalls the tractor and the engine shuts off. i have used it for several hours and it happened twice today. What could be the culprit?
This is what i have domne to the tractor upon picking it up.
There was a vacuum line that went from the top of the valve cover to the fuel filter assembly. I found that the fuel bowl asnt staying full and that was the problem. it has a small hydraulic leak on one hose coming from the pump to loader joystick.
I am gonna change the SuperUdt and Oil later next week.
6,906
Yes you have some serious vent / over flow line issues, they are not vacuum lines. ;)
The line you hooked up is going to the wrong location.
The middle pipe on the tank gets capped.
Inside pipe goes to the one end of the injector overflows, the other end of the injector overflows goes to the injector pump.
The outside pipe goes to the top of the fuel filter housing.
Do all those repairs/ changes then run it and see if it still stalls.
redneckarchery
Oct 18, 2010
45
blountstown,florida
That would explain why the hose coming from the fuel filter was extra long. I hooked it up to the outside line. Now i will cap the middle. The remaining hose will go to the line coming off the injector closest to steering wheel. (See pics)
Tooljunkie
May 13, 2014
4,150
With enough traction, too high range and loading bucket, it will stall.
Our 4610 will stall under the right conditions. Something i try not to do. If its your first go round with hst, less pedal produces more power.
