I have an L4600 with the LA764 FEL. The rear tires aren't loaded so the tractor is too light on the rear end. What should I expect to pay for rear wheel weights? How much weight can I get with rear wheel weights alone?
I'm initially thinking I would pay up and stick with factory Kubota weights but, I would consider a good aftermarket solution. FWIW, I'm trying to avoid water in the tires and I'm considering a heavy box blade which I could use as additional ballast if wheel weights alone are enough but, most of my lifts are nowhere near max capacity so I figure a few hundred pounds of wheel weights would be sufficient for most loader work.
Best Regards,
Sid
Best Regards,
Sid
