The picture tells me only 3 things, yep it's a rim, yep it's orange, and it's 7" wide.Can someone help and identify this rim
it is on a B6100E tire size is 18X9.5X8
this is a new one that came on the tractor when i got it
I need another one for the other side
Thanks for any Help
Pop Pop
Wouldn't the rim be agnostic to the kind of tread on the tire? I always thought they were made to handle certain weight loads, not tread types... I'm asking out of curiosity...Big Kahuna, I think you could be right.
I guess it would also be good to know if it's an AG treaded tire or Turf tire.
The center hole is about 3 1/2POP POP,
Go back and read my post.
In order to get you the right rim, we need to know all the information I asked for.
I realize that it's on the tractor, But what's to say the front axle is a B6100!
If the rim is the wrong size for a b6100, maybe the hubs are not for a B6100 either?
You understand why all the information is important.
ThanksPop Pop,
There is a much cheaper way to get the rims you need.
Tucker tire should be able to hook you up.
1-888-248-7146
Forget about the Kubota #'s as they do very little for you.
What you need is the information here in this picture (double check measurements), I think the only measurement you didn't provide is the center to center measurement.
Hmmm... I've always just gone by Rim diameter/width, Hole spacing, center bore size and weight rating then found the tires that fit it...Ag (r1), industrial (r4) & turf (r3) all use very different size rims. Turf are much wider & shorter, ag are tall & skinny with industrials being somewhere in the middle.
