I recently changed the ring and o-ring on my hydraulic lift piston. After re-assembly, I now have a slow leak from the bottom of the cylinder cap when the unit is under pressure (lifting).
My plan is to remove the cylinder cap again, then replace the o-rings
(#96319-01410) and (#04811-00160).
Questions: What is the proper torque (ft/lbs) for the four cylinder cap bolts? Is there a torque sequence?
I will also closley inspect the cylinder cap for cracks, or other damage, etc.
If there is no damage to the cap, can I use a silicon gasket sealer around the rim of the cap to prevent leakage?
Any advice would be greatly apreciated. Thanks
