Blowing hydro filters
rnoel18
bx23
May 11, 2014
sunman in
I have a BX23, I just replaced the trany. Now it keeps blowing the hydraulic filter when I crank it. What could this be?
6,599
Fluid is not flowing to where it needs to, and is building up way too much pressure.
Did you do all of the rebuild yourself?
rnoel18
bx23
May 11, 2014
sunman in
Its a new trany from our local Kubota dealer. Its almost like a pressure relief is sticking, but I cant find it.
6,599
The relief valve is on the bottom of the three point control valve.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
10
East Hampton, CT
Sounds silly but when you say blowing filters, do you mean blowing out the o-ring or physically exploding the metal? If you have the wrong filter diameter/style on there, the gasket won't line up and will cause blow outs.
Also, if you have a FEL but its disconnected, you need to hook up the hoses correctly so the system bypasses. If you're stuck against the detent, that's bad news too and will cause your tranny to go again.
